2021-04-19 02:41 PM
I have made a custom board based on the STM32F746. I am using a touch panel which uses the FT5436. My question is: are the FT5336 drivers provided by with the STM32F746 discovery board drivers compatible with the FT5436? I cannot make it work. I cannot find any information about FT5436. Thank you!
2021-04-19 02:50 PM
support@focaltech-systems.com
What's the Part# of the PANEL you've selected?
2021-04-19 03:03 PM
Thank you for your reply. I am using 4DLCD-70800480-CTP.
2022-01-31 01:09 PM
Hi, did you find the solution for FT5436 driver? If so, could you please share it?
2022-01-31 06:35 PM
The FT5336 drivers are compatible with FT5436. It turned out that my issue was hardware related.
2022-02-01 02:21 AM
Good to know! Thank you for information.
