2021-12-31 3:19 AM
/* USER CODE BEGIN Header */
* @file : main.c
* @brief : Main program body
* @attention
* Copyright (c) 2021 STMicroelectronics.
* All rights reserved.
/* USER CODE END Header */
#include "main.h"
/* Private includes ----------------------------------------------------------*/
/* USER CODE END Includes */
/* USER CODE BEGIN PTD */
/* USER CODE END PTD */
/* USER CODE BEGIN PD */
/* USER CODE END PD */
/* USER CODE BEGIN PM */
/* USER CODE END PM */
UART_HandleTypeDef huart1;
/* USER CODE BEGIN PV */
/* USER CODE END PV */
static void MX_USART1_UART_Init(void);
/* USER CODE BEGIN PFP */
/* USER CODE END PFP */
/* Private user code ---------------------------------------------------------*/
/* USER CODE BEGIN 0 */
uint8_t data[] = {"A"};
uint8_t data_1[] = {"T"};
uint8_t startLedToggle = 0;
/* USER CODE END 0 */
* @brief The application entry point.
* @retval int
int main(void)
/* USER CODE BEGIN 1 */
/* USER CODE END 1 */
HAL_Init();
/* USER CODE BEGIN Init */
/* USER CODE END Init */
SystemClock_Config();
/* USER CODE BEGIN SysInit */
/* USER CODE END SysInit */
MX_GPIO_Init();
MX_USART1_UART_Init();
/* USER CODE BEGIN 2 */
/* USER CODE END 2 */
/* Infinite loop */
/* USER CODE BEGIN WHILE */
//HAL_UART_Transmit(&huart1, data, sizeof (data), 100);
while (1)
if(startLedToggle == 255)
HAL_UART_Transmit_IT(&huart1, data_1, sizeof (data_1));
HAL_GPIO_WritePin(LED_P4A_GPIO_Port, LED_P4A_Pin, 1);
HAL_Delay(1000);
else if(startLedToggle == 0)
HAL_UART_Transmit_IT(&huart1, data, sizeof (data));
HAL_GPIO_WritePin(LED_P4A_GPIO_Port, LED_P4A_Pin, 0);
HAL_Delay(1000);
else
/* USER CODE END WHILE */
/* USER CODE BEGIN 3 */
/* USER CODE END 3 */
* @brief System Clock Configuration
* @retval None
void SystemClock_Config(void)
RCC_PeriphCLKInitTypeDef PeriphClkInit = {0};
RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSI;
RCC_OscInitStruct.PLL.PLLState = RCC_PLL_NONE;
Error_Handler();
|RCC_CLOCKTYPE_PCLK1;
RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_HSI;
if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_0) != HAL_OK)
Error_Handler();
PeriphClkInit.PeriphClockSelection = RCC_PERIPHCLK_USART1;
PeriphClkInit.Usart1ClockSelection = RCC_USART1CLKSOURCE_PCLK1;
if (HAL_RCCEx_PeriphCLKConfig(&PeriphClkInit) != HAL_OK)
Error_Handler();
* @brief USART1 Initialization Function
* @param None
* @retval None
/* USER CODE BEGIN USART1_Init 0 */
/* USER CODE END USART1_Init 0 */
/* USER CODE BEGIN USART1_Init 1 */
/* USER CODE END USART1_Init 1 */
huart1.Instance = USART1;
huart1.Init.BaudRate = 9600;
huart1.Init.WordLength = UART_WORDLENGTH_8B;
huart1.Init.StopBits = UART_STOPBITS_1;
huart1.Init.Parity = UART_PARITY_NONE;
huart1.Init.Mode = UART_MODE_TX_RX;
huart1.Init.HwFlowCtl = UART_HWCONTROL_NONE;
huart1.Init.OverSampling = UART_OVERSAMPLING_16;
huart1.Init.OneBitSampling = UART_ONE_BIT_SAMPLE_DISABLE;
huart1.AdvancedInit.AdvFeatureInit = UART_ADVFEATURE_NO_INIT;
if (HAL_UART_Init(&huart1) != HAL_OK)
Error_Handler();
/* USER CODE BEGIN USART1_Init 2 */
/* USER CODE END USART1_Init 2 */
* @brief GPIO Initialization Function
* @param None
* @retval None
/* GPIO Ports Clock Enable */
__HAL_RCC_GPIOA_CLK_ENABLE();
/*Configure GPIO pin Output Level */
HAL_GPIO_WritePin(LED_P4A_GPIO_Port, LED_P4A_Pin, GPIO_PIN_RESET);
/*Configure GPIO pin : LED_P4A_Pin */
GPIO_InitStruct.Pin = LED_P4A_Pin;
GPIO_InitStruct.Mode = GPIO_MODE_OUTPUT_PP;
HAL_GPIO_Init(LED_P4A_GPIO_Port, &GPIO_InitStruct);
/* USER CODE BEGIN 4 */
void HAL_UART_TxCpltCallback(UART_HandleTypeDef *huart)
startLedToggle = ~startLedToggle;
/* USER CODE END 4 */
* @brief This function is executed in case of error occurrence.
* @retval None
void Error_Handler(void)
/* USER CODE BEGIN Error_Handler_Debug */
/* User can add his own implementation to report the HAL error return state */
__disable_irq();
while (1)
/* USER CODE END Error_Handler_Debug */
#ifdef USE_FULL_ASSERT
* @brief Reports the name of the source file and the source line number
* where the assert_param error has occurred.
* @param file: pointer to the source file name
* @param line: assert_param error line source number
* @retval None
void assert_failed(uint8_t *file, uint32_t line)
/* USER CODE BEGIN 6 */
/* User can add his own implementation to report the file name and line number,
ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
/* USER CODE END 6 */
#endif /* USE_FULL_ASSERT */
With the above code I'm trying to send a character from STM32F030F4P6 to PC, but the transmitted character is not received in PC teraterm terminal. I observed the RXNE register is set and also framing error and overrun error is set. My teraterm configuration below:
Could you people please explain me why the RXNE and ORE bits are set also the reason for setting FE bit as well.
Thanks in advance!!!
2021-12-31 10:42 PM
I don't think this is your problem, but "sizeof (data_1)" is not what you think it is. "C" compilers always add a trailing NULL (zero) byte to strings in double quotes. So data_1[] contains 2 byges: the letter 'A' and a NULL byte. Use strlen() if you initialize using a string in double quotes.
2021-12-31 10:59 PM
Do you have means to test if your Prolific adapter is working properly? I had a Prolific "clone" that was not working properly with the Prolific driver. (Prolific took some measures against Chinese counterfit). You could try to echo on your board by connecting TX to RX or do the same on the PC side to narrow down the problem to the PC side or the MCU side.
2022-01-01 3:14 AM
Framing and overrun are receiver errors. Framing means the USART did not see a clean start bit to stop bit data frame. Overrun means the receiver has incoming data but the receive data buffer has not been cleared. To clear these errors read the USART status, then the data register. If the errors persist you have incoming noise creating false triggers for the USART receiver.
Do an end to end test of your board first by connecting the RS-232 TX pin to RX pin, instead of to a PC. Program a test to send one character and verify you can receive it (after clearing any RX errors). If you still get errors you have a hardware problem.
Jack Peacock
2022-01-02 7:13 AM
Hello @Community member Thanks for your reply.
I have made the loop back connection in my HW, (Tx to RX) and checked for sending a one char and there are no FE and ORE, but while trying to send more than one characters observed ORE.
After that I have changed the code to transmit one char to tera term but I still observing the garbage value in the tera term. I have include the code below, in this the code I have tried to transmitting more than one character. But still seeing the RXNE and ORE bit are set, can you please guide why these receive operation bits are set even nothing is transmitting from the tera term.
* @file : main.c
* @attention
#include "main.h"
uint8_t data_1[10] = {"UARTTEST"};
uint8_t rx_data[10] = {"uarttest"};
/*uint8_t data_1[1] = {"P"};
uint8_t rx_data[1] = {"r"};*/
static HAL_StatusTypeDef rtrnVal = HAL_ERROR;
static HAL_StatusTypeDef rtrnl = HAL_ERROR;
* @retval int
int main(void)
HAL_Init();
MX_GPIO_Init();
/* Infinite loop */
while (1)
#if 1
rtrnVal = HAL_UART_Transmit_IT(&huart1, data_1, 10);
/*if(rtrnVal == HAL_OK)
rtrnl = HAL_UART_Receive_IT(&huart1, rx_data, 10);
if(rtrnl == HAL_OK)
HAL_GPIO_TogglePin(LED_P4A_GPIO_Port, LED_P4A_Pin);
#endif
#if 0
if((rtrnl == HAL_OK) && (startLedToggle == 1))
if((rtrnVal == HAL_OK) && (startLedToggle == 2))
#endif
* @retval None
Error_Handler();
Error_Handler();
Error_Handler();
* @param None
* @retval None
Error_Handler();
* @param None
* @retval None
//startLedToggle = ~startLedToggle;
startLedToggle = 2;
void HAL_UART_RxCpltCallback(UART_HandleTypeDef *huart)
startLedToggle = 1;
* @retval None
__disable_irq();
while (1)
* @retval None
2022-01-02 5:41 PM
There are a lot of issues with that code. For example, HAL_UART_Receive_IT should not be called repeatedly. You need to wait for the previous transaction to complete before starting a new one.
As mentioned, ORE and FE are receiver errors. Perhaps you start receiving in the middle of a byte, or perhaps the UART receives data while it is not ready due to the previous call being complete. The Reference Manual is very specific about the causes of these errors.
2022-01-03 1:00 AM
Hello @TDK Thanks for your reply. Apologies for attaching the code with the reception functionality, here the discussion is about transmission, not for reception of USART. Now modified the clock source as external 8MHZ and even adding a delay of a sec between the character transmission but no improvement. Please see the attached code below
* @file : main.c
* @attention
#include "main.h"
static uint8_t data_1[] = {'U'};
static uint8_t data_2[] = {'A'};
static uint8_t data_3[] = {'R'};
static uint8_t data_4[] = {'T'};
static uint8_t data_5[] = {'T'};
static uint8_t data_6[] = {'E'};
static uint8_t data_7[] = {'S'};
static uint8_t data_8[] = {'T'};
static HAL_StatusTypeDef txfrRtrnVal = HAL_ERROR;
* @retval int
int main(void)
HAL_Init();
MX_GPIO_Init();
/* Infinite loop */
while (1)
txfrRtrnVal = HAL_UART_Transmit_IT(&huart1, data_1, 1);
HAL_Delay(1000);
if(startLedToggle == 1)
txfrRtrnVal = HAL_UART_Transmit_IT(&huart1, data_2, 1);
HAL_Delay(1000);
if(startLedToggle == 2)
txfrRtrnVal = HAL_UART_Transmit_IT(&huart1, data_3, 1);
HAL_Delay(1000);
if(startLedToggle == 3)
txfrRtrnVal = HAL_UART_Transmit_IT(&huart1, data_4, 1);
HAL_Delay(1000);
if(startLedToggle == 4)
txfrRtrnVal = HAL_UART_Transmit_IT(&huart1, data_5, 1);
HAL_Delay(1000);
if(startLedToggle == 5)
txfrRtrnVal = HAL_UART_Transmit_IT(&huart1, data_6, 1);
HAL_Delay(1000);
if(startLedToggle == 6)
txfrRtrnVal = HAL_UART_Transmit_IT(&huart1, data_7, 1);
HAL_Delay(1000);
if(startLedToggle == 7)
txfrRtrnVal = HAL_UART_Transmit_IT(&huart1, data_8, 1);
HAL_Delay(1000);
if(startLedToggle == 8)
* @retval None
RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSE;
RCC_OscInitStruct.HSEState = RCC_HSE_ON;
Error_Handler();
RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_HSE;
Error_Handler();
Error_Handler();
* @param None
* @retval None
Error_Handler();
* @param None
* @retval None
__HAL_RCC_GPIOF_CLK_ENABLE();
startLedToggle++;
* @retval None
__disable_irq();
while (1)
* @retval None
in this I could see the variable startLedToggle is getting increased for every sec and once it reached the value of 8 it is holding. Thanks in advance!!!
