Flash loader problem
dsokass
Posted on November 06, 2014 at 11:45
Hello! I am trying to load a VCP example code to my STM32F303 Discovery board, but i get error:    Flash loader: Failed to setup call to 'flash init'. I am using EWARM. Maybe someone knows the solution to this error.
#stm32f303
2 REPLIES 2
ArturasV
Senior
Posted on November 06, 2014 at 15:20
Are you sure that you checked ''use flash loader(s)'' under Project options->Debugger->downloads?
megahercas6
Senior
Posted on November 07, 2014 at 12:39
same apply are you correctly set SWD/JTAG ?
usually as default it uses JTAG
