Failure when Configuring UART2 in the STM32C031C6
‎2023-04-11 12:22 AM
When configuring UART2 in the STM32C0316-DK, the emulator is locked.
Error in executing 'step' command ...
Target is not responding, retrying...
Code is running here (stm32c0xx_hal_msp.c line 272):
/**USART2 GPIO Configuration
PA8 ------> USART2_TX
PA13 ------> USART2_RX
GPIO_InitStruct.Pin = GPIO_PIN_8;
GPIO_InitStruct.Alternate = GPIO_AF1_USART2;
GPIO_InitStruct.Pin = GPIO_PIN_13;
GPIO_InitStruct.Alternate = GPIO_AF4_USART2;
Need you help.
Tim
- Labels:
STM32C0 Series
UART-USART
‎2023-04-11 12:36 AM
Hello @tpeng.1​ ,
this is quite common mistake, you reconfigured one of your pins used for debug (PA13). You should use other pins for the USART2, when you want to use SWD.
BR,
Jaroslav
Hello @tpeng.1​ ,
BR,
Jaroslav
‎2023-04-11 12:57 AM
Thank you very much for your quick response!
Now I understand that PA13 is used for debug.
Br,
Tim
