2013-02-20 08:52 PM
I am using STM32F107rb for ethernet communication. By default in the code it as been set to 10Mbps but i want to change it to 100Mbps so please let me Known where i need to change.... The corresponding code as been attached pls go through.... Thank u in advance
2013-02-20 09:22 PM
You'll probably want to look at the PHY code, this is for a DP83848, does your board have this, or something else? What board/ethernet circuit are you using?
2013-02-21 12:46 AM
Yes, I am using DP8384 as my Physical Transceiver..
2013-02-21 05:14 AM
You need to acknowledge the reply to the thread you started in the Keil forum:
