Error while connecting g070rb
AVerm.4
When i try to connect g070rb nucleo board i get my LD1 blinking continuously and on my pc it shows usb device not detected​.
3 REPLIES 3
Guru
Perhaps you are using a USB power-only cable. Try a different cable. Try a different USB port. Reboot your PC. Try a different board. Try a different computer.
AVerm.4
@TDK​  Checked all the possible situations you mentioned. It's been couple of months since i used this board. I'm not able to figure out what exactly is happening. Is there any way i can connect to Stlink v2 externally.​?
Mohamed Aymen HZAMI
Hello @Community member​,
Try to reinstall the board driver on your computer.
Mohamed Aymen.
