#error "Compiler generates FPU instructions for a device without an FPU (check __FPU_PRESENT)"
CWang.2
Hi, I downloaded X-CUBE-DSPDEMO from https://my.st.com/content/my_st_com/en/products/embedded-software/mcu-mpu-embedded-software/stm32-embedded-software/stm32cube-expansion-packages/x-cube-dspdemo.license=1593557368708.product=X-CUBE-DSPDEMO.version=1. 0.0.html
When I try to compile the STM32F746_DSPDEMO from Keil, i.e., MDK-ARM version of the code, I get the following errors, what is wrong?
Build started: Project: Project
*** Using Compiler 'V5.06 update 6 (build 750)', folder: 'C:\Keil_v5\ARM\ARMCC\Bin'
Build target 'X-CUBE-DSPDEMO'
compiling main.c...
compiling DistanceFunctions.c...
..\..\..\..\Drivers\CMSIS\Include\core_cm7.h(129): error: #35: #error directive: "Compiler generates FPU instructions for a device without an FPU (check __FPU_PRESENT)"
C:\Local\Arm\Packs\ARM\CMSIS\5.7.0\CMSIS\DSP\Source\DistanceFunctions\DistanceFunctions.c: 0 warnings, 1 error
compiling FastMathFunctions.c...
C:\Local\Arm\Packs\ARM\CMSIS\5.7.0\CMSIS\DSP\Source\FastMathFunctions\FastMathFunctions.c: 0 warnings, 1 error
compiling FilteringFunctions.c...
C:\Local\Arm\Packs\ARM\CMSIS\5.7.0\CMSIS\DSP\Source\FilteringFunctions\FilteringFunctions.c: 0 warnings, 1 error
compiling MatrixFunctions.c...
C:\Local\Arm\Packs\ARM\CMSIS\5.7.0\CMSIS\DSP\Source\MatrixFunctions\MatrixFunctions.c: 0 warnings, 1 error
compiling SVMFunctions.c...
C:\Local\Arm\Packs\ARM\CMSIS\5.7.0\CMSIS\DSP\Source\SVMFunctions\SVMFunctions.c: 0 warnings, 1 error
compiling StatisticsFunctions.c...
C:\Local\Arm\Packs\ARM\CMSIS\5.7.0\CMSIS\DSP\Source\StatisticsFunctions\StatisticsFunctions.c: 0 warnings, 1 error
compiling SupportFunctions.c...
C:\Local\Arm\Packs\ARM\CMSIS\5.7.0\CMSIS\DSP\Source\SupportFunctions\SupportFunctions.c: 0 warnings, 1 error
compiling TransformFunctions.c...
C:\Local\Arm\Packs\ARM\CMSIS\5.7.0\CMSIS\DSP\Source\TransformFunctions\TransformFunctions.c: 0 warnings, 1 error
compiling BayesFunctions.c...
C:\Local\Arm\Packs\ARM\CMSIS\5.7.0\CMSIS\DSP\Source\BayesFunctions\BayesFunctions.c: 0 warnings, 1 error
compiling ComplexMathFunctions.c...
C:\Local\Arm\Packs\ARM\CMSIS\5.7.0\CMSIS\DSP\Source\ComplexMathFunctions\ComplexMathFunctions.c: 0 warnings, 1 error
compiling BasicMathFunctions.c...
C:\Local\AppData\Local\Arm\Packs\ARM\CMSIS\5.7.0\CMSIS\DSP\Source\BasicMathFunctions\BasicMathFunctions.c: 0 warnings, 1 error
compiling ControllerFunctions.c...
C:\Local\Arm\Packs\ARM\CMSIS\5.7.0\CMSIS\DSP\Source\ControllerFunctions\ControllerFunctions.c: 0 warnings, 1 error
compiling CommonTables.c...
C:\Local\Arm\Packs\ARM\CMSIS\5.7.0\CMSIS\DSP\Source\CommonTables\CommonTables.c: 0 warnings, 1 error
compiling LCDConf.c...
"STM32746G_DISCOVERY\X-CUBE-DSPDEMO.axf" - 13 Error(s), 0 Warning(s).
Target not created.
Build Time Elapsed: 00:00:12
5 REPLIES 5
The __FPU_PRESENT should be defined within a header file or specified on the compiler options prior to including core_cm7.h.
Looks like it's defined in:
https://raw.githubusercontent.com/STMicroelectronics/STM32CubeF7/master/Drivers/CMSIS/Device/ST/STM32F7xx/Include/stm32f746xx.h
CWang.2
Thanks very much for your reply!
I see it is defined in global.h, which is the first include in main.h. How can I make sure it gets included first?
In main.h:
/* Define to prevent recursive inclusion -------------------------------------*/
#ifndef __MAIN_H
#define __MAIN_H
#include "global.h"
#include "display.h"
In global.h:
#ifndef __GLOBAL_H
#define __GLOBAL_H
#define __FPU_PRESENT       1    /*!< FPU present */
Go into your source file, and look at the order of includes to ensure global.h gets included before whatever is including core_cm7.h. In the HAL architecture, you do this by including "stm32f746xx.h" in your source file, which will go and include the other files for you.
Kolab
ensure that the microcontroller set on CubeMX is the same one you have on your board
Not clear that CubeMX is involved.
If it's a pre-build MDK project, one might go to the target and build panes, making sure the right model, compiler, and floating point selection is available. The F746 only has the FPU-S (Single Precision)
The compiler used by the OP also looks quite old (even for 2 years ago), most of ST's projects are going to target something newer.
