2015-09-19 01:20 AM
hi,
Trying to make an intial configuration project with CubeMX for the STM32F746G-Discovery. When I select the board itself and instruct CubeMX to generate all board's known IPs, it places in the LTDC width and height the 640x480 pixel resolution, whereas the actual LCD according to specs is 480x272 pixel resolution. Should we rely on the CubeMX generated code for the board?2015-09-28 09:36 AM
Hi christos,
Thank you for your feedback. The issue has been reported internally.-Syrine-2016-03-22 11:40 AM
Dear user,
Thank you for reporting this issue. The solution is available since STM32CubeMX 4.11. Best regards
