Error description in SPL
Options
2014-11-26 7:21 AM
Posted on November 26, 2014 at 16:21
So,
Timing Parameters for write and read access if the Extended Mode is not used
Wrong!
Parameter used for read operation.
Check FSMC_NORSRAMInit( *p) from stm32f4xx_fsmc.c it without assert()
Options
2014-11-27 8:06 AM
Posted on November 27, 2014 at 17:06
Could you please provide more details on the error you are reporting:- What is the used SPL version?- Which parameter?...-Mayla-To give better visibility on the answered topics, please click on Accept as Solution on the reply which solved your issue or answered your question.
