2020-06-13 12:02 AM
Im working on stm32l4 series ,using external eeprom , eeprom writes four variables in 4 EEPROM addresses succesfully,but while reading EEPROM it only reads last (4th) variable on all 4 EEPROM address,Im try all methods adjusting delay ,EEPROM addresses,Device address of I2C but same problem occurs ,Please help me & Thanks in Advance for your suggetions
2020-06-14 6:34 AM
Probably you are actually writing and reading a single variable...
2020-06-15 12:24 AM
No I'm writing & reading on 4 different variable
2020-06-15 3:41 AM
Here is my code,
while (1)
/* USER CODE END WHILE */
/* USER CODE BEGIN 3 */
//EEPROM Write code
uint8_t ret = HAL_I2C_Mem_Write(&hi2c1, I2C1_EEPROM_ADDR, 10, I2C_MEMADD_SIZE_16BIT,(uint8_t *) &shift_flag, 4, 0xFF);
printf("%d %d\r\n", ret, shift_flag);
printf("%x\r\n", I2C1_EEPROM_ADDR);
HAL_Delay(10);
ret = HAL_I2C_Mem_Write(&hi2c1, I2C1_EEPROM_ADDR, 20, I2C_MEMADD_SIZE_16BIT,(uint8_t *) &onoff_flag, 4, 0xFF);
printf("%d %d\r\n", ret, onoff_flag);
HAL_Delay(10);
ret = HAL_I2C_Mem_Write(&hi2c1, I2C1_EEPROM_ADDR, 30, I2C_MEMADD_SIZE_16BIT,(uint8_t *) &Stream1_flag, 4, 0xFF);
printf("%d %d\r\n", ret, Stream1_flag);
HAL_Delay(10);
ret = HAL_I2C_Mem_Write(&hi2c1, I2C1_EEPROM_ADDR, 40, I2C_MEMADD_SIZE_16BIT,(uint8_t *) &Stream2_flag, 4, 0xFF);
printf("%d %d\r\n", ret, Stream2_flag);
HAL_Delay(10);
ret = HAL_I2C_Mem_Write(&hi2c1, I2C1_EEPROM_ADDR, 50, I2C_MEMADD_SIZE_16BIT,(uint8_t *) &fire_flag, 4, 0xFF);
printf("%d %d\r\n", ret, fire_flag);
HAL_Delay(2000);
shift_flag = 0;
onoff_flag = 0;
Stream1_flag = 0;
Stream2_flag = 0;
fire_flag = 0;
//Reading EEPROM code :
uint8_t g = HAL_I2C_Mem_Read(&hi2c1, I2C1_EEPROM_ADDR, 10, I2C_MEMADD_SIZE_16BIT,(uint8_t *) &shift_flag, 2, 0xFF);
printf("%d %d\r\n", g, shift_flag);
HAL_Delay(10);
g = HAL_I2C_Mem_Read(&hi2c1, I2C1_EEPROM_ADDR, 20, I2C_MEMADD_SIZE_16BIT,(uint8_t *) &onoff_flag, 2, 0xFF);
printf("%d %d\r\n", g, onoff_flag);
HAL_Delay(10);
g = HAL_I2C_Mem_Read(&hi2c1, I2C1_EEPROM_ADDR, 30, I2C_MEMADD_SIZE_16BIT,(uint8_t *) &Stream1_flag, 2, 0xFF);
printf("%d %d\r\n", g, Stream1_flag);
HAL_Delay(10);
g = HAL_I2C_Mem_Read(&hi2c1, I2C1_EEPROM_ADDR, 40, I2C_MEMADD_SIZE_16BIT,(uint8_t *) &Stream2_flag, 4, 0xFF);
printf("%d %d\r\n", g, Stream2_flag);
HAL_Delay(10);
g = HAL_I2C_Mem_Read(&hi2c1, I2C1_EEPROM_ADDR, 50, I2C_MEMADD_SIZE_16BIT,(uint8_t *) &fire_flag, 4, 0xFF);
printf("%d %d\r\n", g, fire_flag);
HAL_Delay(10);
Here is Print Values:
Scanning I2C bus:
...............................................................................0x500x510x520x530x540x550x560x57........................................
0 10
0 20
0 30
0 40
0 50
//below are EEPROM Read Values
0 50
0 50
0 50
0 50
0 50
// EEPROM only reads last(5th) values in all EEPROM addressses,Please give me any suggetions
2020-06-15 3:49 AM
No I'm writing & reading on 5 different variable
Here is my code,
while (1)
//EEPROM Write code
HAL_Delay(10);
HAL_Delay(10);
HAL_Delay(10);
HAL_Delay(10);
HAL_Delay(2000);
shift_flag = 0;
onoff_flag = 0;
Stream1_flag = 0;
Stream2_flag = 0;
fire_flag = 0;
HAL_Delay(10);
HAL_Delay(10);
HAL_Delay(10);
HAL_Delay(10);
HAL_Delay(10);
Scanning I2C bus:
0 10
0 20
0 30
0 40
0 50
0 50
0 50
0 50
0 50
0 50
