2024-04-10 07:26 AM
I'm working with a legacy project that uses some EEPROM emulation code on a STM32F103 MCU. I need to find the original release file containing eeprom.c and eeprom.h of that emulation code. The description of the header file looks like this:
/******************** (C) COPYRIGHT 2008 STMicroelectronics ********************
* File Name : eeprom.h
* Author : MCD Application Team
* Version : V2.0.0
* Date : 06/16/2008
* Description : This file contains all the functions prototypes for the
* EEPROM emulation firmware library.
As you can see this is very old code. Is there a place where I can find the original release package that contained these files?
I was able to find similar, much newer code but not that exact release/version.
Thanks a lot!
2024-04-10 08:07 AM
See attachement.
2024-04-10 08:07 AM
2024-04-10 08:20 AM
Thanks a lot! Very helpful!
How were these files distributed once? Were they part of bigger package or of some library?
2024-04-10 08:59 AM - edited 2024-04-10 09:01 AM
I found it in my archive and believe me, you're lucky
Please "Accept as solution" my answer if you got what you need.
Thank you.
2024-04-10 09:31 AM
Yes, part of SPL or as an App Note
STSW-STM32010
EEPROM emulation in STM32F101xx and STM32F103xx microcontrollers (AN2594)
https://www.st.com/en/embedded-software/stsw-stm32010.html
Mirror http://www.bdtic.com/en/st/stsw-stm32010
