Dynamically change Period and Prescaler
pass3master
We are using interrupt of timer function.
Currently, Period and Prescaler are set in the initial settings (MX_TIM6_Init), but what should I do if I want to dynamically change Period and Prescaler?
[IDE]STM32CubeIDE 1.14.0
[board]​ STM32F412 Discovery kit
Thank you for your response.
Close because your perfect answer helped me to solve the problem.
gbm
Lead III
Just write new values to PSC and ARR register. Make sure that ARR preload option is turned on.
