ZKURT.1
December 15, 2021
defined things called "undeclared"
  • December 15, 2021
  • 9 replies
  • 4340 views
Hi, my processor is STM32L010C6TX. I added function to my project to use microsecond But " DWT" "CTRL" etc. It says not defined. However, they are all in the "core_cm4.h" library. This library is in Drivers-> CMSIS->Include. why doesn't it call this function and say "undeclared"?
ZKURT.1
ZKURT.1Author
December 15, 2021
waclawek.jan
Maybe you don't have given header file included (directly or indirectly) in the source file where the error occurs.
Try to #include it explicitly.
 [EDIT] Nikita91 below ecplained, why.[/EDIT]
Nikita91
Lead II
December 15, 2021
The STM32L010C6TX use a M0+ core not a M4 core. So look at core_cm0plus.h
In M0/M0+ core there is no DWT
ZKURT.1
ZKURT.1Author
December 16, 2021
Hello, thank you very much for your information.
Is there any other way to use this library?
ZKURT.1
ZKURT.1Author
December 16, 2021
@Khouloud OTHMAN​  ST should really do a better job here of only copying the core file(s) used by that family. There's no reason to have headers for all different Cortex types within a project. No need to have Cortex-M4 specific files in a Cortex-M0+ project.
ZKURT.1
ZKURT.1Author
December 16, 2021
ZKURT.1
ZKURT.1Author
December 16, 2021
this is the header file
Nikita91
Lead II
December 16, 2021
You can't. The M0+ doesn't have DWT.
You have to use a timer to do the same thing.
