Debug the code using UART(USB-TTL)
2022-05-19 12:09 AM
I am using STM32F103(Bluepill). Since I am not able to load program to the controller through ST-LINK V2 programmer, so not able debug the code.
I am loading the program through UART(USB-TTL)
I want to know if there is a way to debug the code using UART(USB-TTL), i want to analyze the real time memory traces.
STM32F1 Series
UART-USART
2022-05-19 1:24 AM
"I am not able to load program to the controller through ST-LINK V2 programmer"
Because it's a bricked clone:
https://community.st.com/s/question/0D53W00001YdJPkSAN/no-st-link-connected
"I want to know if there is a way to debug the code using UART(USB-TTL)"
Wouldn't it be simpler to just get a working ST-Link (or other debug probe) ?
Anyhow, without a proper debug probe, you're left with just "printf" debugging, and/or writing patterns out to spare IO to observe on a 'scope or logic analyser.
Or maybe get/make yourself an old-school Debug Monitor:
2022-05-19 1:30 AM
Hello @Ax111_ ,
You can use print on UART and "instrumentalize" the code.
If needed there is an example in Step3 of the STM32MCUwiki.
2022-05-19 1:44 AM
From that last link:
"MRI - Monitor for Remote Inspection
MRI is a debug monitor which allows the GNU debugger, GDB, to debug Cortex-M3/M4 processors. This makes it possible to debug applications running on Cortex-M devices using a full featured source level debugger with no extra hardware other than a serial connection."
