CubeMX became a cloud application
‎2018-01-23 9:21 PM
So, the 4.24 version won't generate anything if it does not have an internet connection. Even if there is firmware in repository...
Now I'm loving the earlier version with a passion!
‎2018-01-23 11:40 PM
I tried offline mode and it does throw a bunch of 'HTTP server not found' errors when starting a new project, referencing the following files:
mcusDocs.json
mcusFeaturesAndDescription.jsonmcusAds.jsonboardsDocs.jsonboards.jsonAfter clicking Ok on all dialogs it appears to work fine for me, however.
‎2018-01-24 4:35 AM
I made it work as I wanted, eventually. But the feeling that there are options that were not supposed to be available for everyone, is still there - the Makefile project generation is still rendered unusable and measures are taken to remain that way in the foreseeable future (hiding the Makefile.tpl).
‎2018-01-24 5:51 AM
Version 4.23.0 tried to update its MCU database (I guess) when you started new project only.
‎2018-01-24 6:06 AM
With 4.23 version the things are ok, if you tell it to work exclusively local, it will do just that. I have it on manual regarding update checks. On the other hand, 4.24 behavior is cloud like, I think is testing the waters.
‎2018-01-24 6:17 AM
It seems they invest in non-core features. I am somewhat disappointed by the 4.24 - first test I did just failed (reported LL issues in separate thread).
‎2018-01-24 9:51 AM
Have they learned nothing from the cloud-based disaster of Jive ... ?
‎2018-01-24 12:23 PM
To exclude some unfortunate coincidence at Vasile's place, can somebody else please confirm this behaviour?
ST's comment would be nice, too.
‎2018-01-24 1:48 PM
Disabled the WIFI (the only internet connection) and generated simple project for the device I have never used.
Seems to work fine.
‎2018-01-24 8:30 PM
So, nobody observed that the upgrade of the software itself is no longer optional?
