CubeMX 4.20.1 Properties does not appear
‎2017-04-26 12:53 PM
In CubeMX 4.20.1 I have opened a project from a previous version. Then when I go to edit the Properties... no window comes up! If I open another project or create a new one, the Properties... window appears as expected.
How do I fix this? I need to review and possibly change the properties!
thanks!
‎2017-04-27 2:19 AM
Please share your .ioc to check this case.
Imen
Imen
‎2017-05-03 1:20 AM
Hello
Liebman.Mark.002
,I had a look to your point. I took an ioc from CubeMX4.0 and open it with CubeMX4.1.
I can open Project/Settings/, open the configuration of IPs etc...
What do you mean by properties? Is it Project Settings?
As I can't reproduce the issue and as Imen said, we need you to share your ioc to progress on this point.
BR. Eric
‎2017-05-03 5:14 AM
Yes, it was the project settings dialog which would not appear when selected from the menu. In that project it was never seen. If I see it again I will share.
