2017-05-11 5:51 AM
I did upgrade to cube 4.21 and for 1 project, when generating the source code, cube MX hangs.
I have to specify that it hangs only for 1 of my project.
2017-05-11 6:41 AM
Hi
Castrignano.Adalgiso
,Couldyou please share the log files placed inyour user directory under the .stm32cubemx folder.
-Nesrine-
2017-05-11 7:03 AM
Hi
,Hi, Can you specify how to share a file, I searched on the forum but could not find a way to attach a file?
-Nesrine-
2017-05-11 9:11 AM
Cube 4.21 lib 1.60 for STM32F2.
________________ Attachments : STM32CubeMX.log.zip : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006Hyfd&d=%2Fa%2F0X0000000bAl%2FCCHs6MY0mzyjBTFBpH5ua9Q7nYwBAec1W_sUPUZ96uY&asPdf=false2017-05-13 6:16 PM
Probably too obvious an answer but I have found that CubeMX will hang when generating project if uVision is already open on that project. The only way to move on is to terminate CubeMX with Windows Task Manager.
2017-05-15 2:26 AM
Hi
,This issue has been reported internally to our MX team for for checking,Sorry for the inconvenience it may bring.
-Nesrine-
2017-05-15 4:05 AM
I am using IAR compiler, and with IAR open or closed I have the same issue and this only on 1 of my project. It works fine for other project. I attached my log file hopefully I will get some feedback from ST team.
2017-06-06 4:31 PM
I see a similar behavior. CubeMX 4.21, building for IAR toolchain, STM32CubeL4 1.8.0. My target is an STM32L486
________________ Attachments : STM32CubeMX.log.zip : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006HycZ&d=%2Fa%2F0X0000000bAC%2FmB8YouABJ_eScl7sCfnjSe7KzgekKiwPqxldHaiUxg4&asPdf=false2017-07-06 1:36 AM
Hi
Any news on this issue, has something been found and if yes by when can we expect a fix or solution?
