clock cycles needed for eeprom write
prudhvichitturi
Hello ,
i am looking to know for STM32L051 how long will it take a byte to be written in to eeprom.
while writing eeprom does it have any limitations like UART intteruptions?
Use a TIM counting off micro-seconds to measure the time across the functions. Or toggle a GPIO and scope it
6 REPLIES 6
Guru
If it's the same as the STM32L1 family (which it probably is), it will not stall the bus unless you read/write to the same bank before the first operation is done.
Datasheet says programming time is 3.94 ms max.
Ironically that time is about 10 to 100 times worse than for a software EEPROM emulation or a proper storage system in FLASH memory.
prudhvichitturi
The below is the function i use ,
 flash_unlock( );
memcpy( &data_w, data_ptr, sizeof( data_w ) );
status = HAL_FLASHEx_DATAEEPROM_Program( TYPEPROGRAMDATA_WORD, Address_Src, INVERTED_DATA( data_w ) );
flash_lock( );
from the above , does it take longer than 3.94?
It shouldn't. Measure it, shouldn't stall at all. Not sure if you can lock the flash when a write is in progress.
