Cannot build STM32Cube_FW_L4 (v1.13) TrueSTUDIO Demo Project
‎2018-10-16 1:24 AM
I'm not able to build Adafruit_LCD_1_8_SD_Joystick out-of-the-box demo for the NUCLEO-L476RG board and TrueSTUDIO 9.0.1 IDE
I had to fix a resource name but it is not enough. Please, can anyone help me with this issue?
thanks in advance,
gaston
‎2018-10-22 3:59 AM
some feedback please?
‎2018-10-22 6:23 AM
Your screenshot has cut off the most of the error message text!
Have you tried putting the messages into google?
Copy & paste the text of the messages to the forum.
‎2018-10-22 11:22 AM
Hi Andrew,
No, I haven't searched for the error and I do not think I should.
It is a demo project provided by ST and It should work (compile at least) as it comes.
I think that some employee of ST would have to try this example and verify that it compiles correctly.
regards,
gaston
‎2018-10-22 11:35 AM
Note that this is a user forum.
If you want to submit this direct to ST, then raise a support case and/or speak to your distributor or FAE.
‎2018-10-22 12:06 PM
‎2018-10-22 12:11 PM
So how about copying & pasting the text of the messages to the forum?
