Calculation of RTC in certain months(Months with 31)
baris.akpinar
Hello everyone,
In my sample project I have created, RTC does not perceive certain months as 31 days. Although it is 31 days in July, October, December, I took the same result in my essays with a code sample with an RTC code.I don't have problems in January, March, and August.
What are your ideas?
July 30 -> 01 august (Problem)
Func:
HAL_RTC_SetTime(&hrtc,&updateTime,RTC_FORMAT_BIN);
HAL_RTC_SetDate(&hrtc,&updateDate,RTC_FORMAT_BIN);
Card I used: F407VG 168mhz
Did you fix your code?
Not sure what you're looking for here. The off-by-one error was clearly the issue.
8 REPLIES 8
Guru
Sure you're not setting the month off by 1? What is your code to set the date to july 30th?
I set up RTC for the time I wanted and then read it.
updateTime.Seconds=SECONDS; // 45
updateTime.Minutes=MINUTES; // 59
updateTime.Hours =HOUR; //23
updateDate.Date = DAY; // 30
updateDate.Month = MONTH; // 06
updateDate.Year = YEAR;
Guru
July is 7, not 6.
My problem is still going on.
With MONTH = 7?
July = 6(Including zero)
My problem was solved, it was wrong to start the months, including zero.Thanks. I'm sorry for my bad english.
