2023-04-13 12:02 PM
I have an .elf file and a .mpa file both in the same directory, Debug-->project.elf and Debug-->project.map and the build analyzer is not showing any information. Any ideas on a possible solution to resolve this? SRM32 CubeIDE Version: 1.12.0
2023-04-14 7:19 AM
Enable also "Generate list file".
If "internal builder" selected, change it to "external".
2023-04-14 11:28 AM
Hi MStev.7
Your question has been routed to the online support team. A case has been created and you'll be contacted shortly.
Kind Regards
Joe WILLIAMS
STMicro Support
