2016-08-10 2:11 PM
Using CubeMX version 4.16.0 with DMA it does not let you turn off FIFO mode. The check mark does not deselect.
2016-08-11 2:07 AM
Hi yarema.andriy ,
Could you please precise which STM32 product are using? So that it will be easier to verify the issue?-Syrine-2016-08-11 10:06 AM
The CubeMX is used to generate code for the STM32F767 Nucleo Board. Same issue was seen when it was used for STM32F746 Nucleo Board.
2016-08-12 2:06 AM
Hi yarema.andriy,
I'll report this issue to our MX team for checking. Sorry for the inconvenience it may bring.-Syrine-
