2017-07-23 7:18 AM
Hi all ,
I used BlueNRG-MS found a problem , the MCU is freescale chip and used SPI communcation with
BlueNRG-MS , but the MCU send the configuration information to BlueNRG-MS , start I could read 0x04 0xFF 0x03 0x01 0x00 0x01, and then write configuration information , but each only read 0x04 0x10 0x01 0x00 . is not the correct data .
This image is first read the data , and comparison of normal board data is correct .
This is every send
configuration information , and read data , is always this data , but normal is not is data .
Please tell me why is read this information ? why reason could read this information ? How to modified my code could read the normal data . Thanks for your attention .
