2023-02-12 10:56 PM
Hello ST community,
I am developing an application based on B-U585I-IOT02A. In this I am using the MX25LM51245G which is on board NOR flash connected via OCTOSPI. The functionality is to save and retrieve a .bin file from the NOR flash. Please let me know how can we achieve the same.
2023-02-28 7:38 AM
Hello @Community member ,
I advise you to get inspired form the Fx_NoR_Write_Read_File example available in STM32CubeU5 package.
This example may help you by following the instructions in the readme file.
Thank you
Kaouthar
2023-02-28 7:38 AM
Thank you
Kaouthar
2023-02-28 8:37 AM
With FatFS we'd use 4KB sectors to match the erase sector/page size of the QSPI/OSPI devices.
NOR Flash isn't particularly fast, and writes will require an erase.
