Ads1220 for STM32F4 example code ?
Anaelle Q
Hi everyone,
I try to find an example code of ads1220 for my stm32F407 MCU.
If someone have it :)
Thank a lot ,
Anaelle
4 REPLIES 4
Clive1 (HNL)
Senior II
Perhaps broaden you search, find other examples you can port yourself. Even ones for different STM32 parts, or different micro-controllers. Find SPI code examples within the HAL BSP trees.
Anaelle Q
Thank for your answer,
Your right, it exits example code for MSP430 ship but the software of this ship is too different compared to STM32.
If someone kwon how to convert the MSP430 software into STM32 ?
Anaelle
Not directly.
At least you should be able to take the sequence of reads/writes from the MSP example, both for initializing the ADC, and for operation.
You need to take care for a proper configuration of the SPI peripheral, perhaps using Cube. The parameters (clock polarities, word sizes, etc. are determined by the slave, i.e. the ADS1220).
WPARK.1
Hello Anaelle, I am having same problem with you. Actually I failed to port Arduino library to Stm32 library. Did you solve the problem?
Thank you for reading.
