2012-02-28 12:00 AM
On my PC(windows 7 32bit)
Create a project named test.erj with 400x240 resolution ,save it and close it.Then open the test.erj project,but the resolution is 320x240.Why? #gui-stm322012-02-29 6:24 PM
Anybody know?
2012-02-29 7:24 PM
It's a forum, nobody cares. If you are reporting a bug you should try your local ST FAE or representatives.
''The library has been developed and tested on an LCD panel of QVGA resolution (320x240) which is the default, but the library is independent to the LCD resolution, although it has not been tested with others.''
