#130: expected a ''''
edgarmedina20
Posted on April 01, 2014 at 21:12
Thank you. I found the problem, the problem was that I forgot '';'' but in other library.
''another.h''//Here I forgot the '';'' in the last line, and this produced the problem. :)
''delay.h''
I have to complete correctly the syntax else Keil maybe will find a problem in others places.
#130:-expected-a-{""
1 REPLY 1
Andrew Neil
Evangelist III
Posted on April 04, 2014 at 20:11
''the problem was that I forgot ';' but in other library''
I think you mean, ''header file'' - not ''library''?
''I have to complete correctly the syntax else Keil maybe will find a problem in others places''
Nothing specifically to do with Keil - that's the way
all
  compilers work!
