WAV File to DAC Problem
GIkar
i read the ST instructions and looked in the EVAL Board example. There they used a audio jack via SPI but in want to play the file direct on DAC.
First to check if the SD Card works i write and read a file to it (works). Then I call the "play_sound" Funktion.
My problems to solve:
  1. Open the file don't work like the text file -> What's the problem
  2. How can I transfer the value of buffer one and two to the DAC. May be via DMA
void play_sound(void)
     uint32_t WaveDataLength=0;
     /* Get Data from SD */
    res=f_open(&myFile, "open_sound_mono.wav", FA_READ); // Don't work. SD Card is already mounted and TXT File write and read worked properly
     res=f_lseek(&myFile, f_size(&myFile));
     res=f_read (&myFile, buffer1, _MAX_SS, &BytesRead);
     res=f_read (&myFile, buffer2, _MAX_SS, &BytesRead);
      res=f_close(&myFile);
     /* Start playing wave */
   //  Play buffer1 on DAC0  HOWTO ???
     buffer_switch = 1;
     while((WaveDataLength != 0) )
         /* wait for DMA transfert complete */
         if(buffer_switch == 0)
           /* Play data from buffer1 */
           /* Store data in buffer2 */
           f_read (&myFile , buffer2, _MAX_SS, &BytesRead);
           buffer_switch = 1;
         else
           /* Play data from buffer2 */
            //  Play buffer2 on DAC0  HOWTO ???
           /* Store data in buffer1 */
           buffer_switch = 0;
          // Wiedergabe Stoppen
         // WavePlayerStop ???
     WaveDataLength = 0;
void DAC_setup()
   HAL_DAC_Start(&hdac, DAC_CHANNEL_1);
   HAL_DAC_Start(&hdac, DAC_CHANNEL_2);
   //HAL_DAC_Start_DMA(&hdac, DAC1_CHANNEL_1 , pData, Length, Alignment)
   HAL_DAC_Start_DMA(&hdac, DAC_CHANNEL_1, (uint32_t*)AUDIO_SAMPLE, 32, DAC_ALIGN_12B_R); //Test with AUDIO_SAMPLE from EVAL Board sample code
7 REPLIES 7
Going to be hard to read any data beyond the end of the file.​
I gues you mean I have to read the file step by step 512byts to the end?
I solved the problem of the output
      HAL_TIM_Base_Start(&htim6);
  HAL_DAC_Start_DMA(&hdac, DAC_CHANNEL_2, (uint32_t*)sine_wave_array, 32, DAC_ALIGN_12B_R);
now I only need to replace the array with the data of the wave file. Do you have a nice idee for this?
Better when i close my file at the end :D
GIkar
         FATFS *fs;    /* Ponter to the filesystem object */
         fs = malloc(sizeof (FATFS));
      res=f_mount(fs ,"", 1);
      if(res!=FR_OK)
         __NOP();
        res = f_open(&myFile, "close_sound_mono.wav", FA_OPEN_EXISTING | FA_READ); --> Why this does not work
         if(res!=FR_OK)
            __NOP();
      res=f_open(&myFile, "test.txt", FA_WRITE | FA_CREATE_ALWAYS); --> this work
      if(res!=FR_OK)
         __NOP();
GIkar
now I can open my wave file. And my function looks like that. ;)
Problem now. DAC only keeps the first value.
   res = f_open(&myAudioFile, "SOUND.WAV", FA_READ); //FA_OPEN_EXISTING |
   if(res!=FR_OK)
      __NOP();
      WaveDataLength=f_size(&myAudioFile);
         // wait for DMA transfert complete
           // Play data from buffer1
            HAL_DAC_Start_DMA(&hdac, DAC_CHANNEL_1, (uint32_t*)buffer1, 32, DAC_ALIGN_12B_R);
            f_lseek(&myAudioFile, f_tell(&myAudioFile)+_MAX_SS);//move 4096 bits
            // Store data in buffer2
           f_read (&myAudioFile , buffer2, _MAX_SS, &BytesRead);
           WaveDataLength=WaveDataLength-_MAX_SS;
           buffer_switch = 1;
         else
           // Play data from buffer2
           HAL_DAC_Start_DMA(&hdac, DAC_CHANNEL_1, (uint32_t*)buffer2, 32, DAC_ALIGN_12B_R);
           // Store data in buffer1
           f_read (&myAudioFile, buffer1, _MAX_SS, &BytesRead);
           buffer_switch = 0;
     WaveDataLength = 0;
          __NOP();
      res = f_close(&myAudioFile);
GIkar
Okay File is loaded step by step to DAC but no proper sound, may the speed is wrong?
CPU Frq = 72MHz
static void MX_TIM6_Init(void) // Trigger for DAC DMA
 /* USER CODE BEGIN TIM6_Init 0 */
 /* USER CODE END TIM6_Init 0 */
 TIM_MasterConfigTypeDef sMasterConfig = {0};
 /* USER CODE BEGIN TIM6_Init 1 */
 /* USER CODE END TIM6_Init 1 */
 htim6.Instance = TIM6;
 htim6.Init.Prescaler = 0;
 htim6.Init.CounterMode = TIM_COUNTERMODE_UP;
 htim6.Init.Period = 32768;
 htim6.Init.AutoReloadPreload = TIM_AUTORELOAD_PRELOAD_DISABLE;
 if (HAL_TIM_Base_Init(&htim6) != HAL_OK)
   Error_Handler();
 sMasterConfig.MasterOutputTrigger = TIM_TRGO_UPDATE;
 if (HAL_TIMEx_MasterConfigSynchronization(&htim6, &sMasterConfig) != HAL_OK)
   Error_Handler();
 /* USER CODE BEGIN TIM6_Init 2 */
 /* USER CODE END TIM6_Init 2 */
