DRP1M1 with NUCLEO-G0B1RE
Alfredo
Hello to All,
When looking into the datasheet of the DRP1M1 addon for USB-PD, it was mentioned that this board could be used together with the NUCLEO-G0B1RE.
However.
The TCPP_V3.0.0 does not contain sources for this nucleo board !
Are they available somewhere else?
Thanks.
11 REPLIES 11
Alfredo
As ST does not respond to the pull for the G01BRE, I have withdrawn the pull.
However, the G01BRE projects are still available at my fork of the library.
https://github.com/LongDirtyAnimAlf/x-cube-tcpp
ALABSTM
Hi @Alfred Glänzer​,
I hope you are fine. Actually, we receive a quite important number of issues and pull-requests and it often take time for us to answer. We count on your patience and comprehension.
I suggest that you reopen your pull-request and it will be forwarded to our development teams for deeper analysis.
With regards,
