where can findMCSDK5.4.3 protocol??
lluke.3
I need to use another mcu to link the motor control which use UART, But i can not find MCSDK 5.4.3 protocol, UM1052 is not the suggest document by ST.
4 REPLIES 4
CLutz.1
Sorry, I'm not shure. But I think protocoll was part of old MCSDK docmentation. You can check e.g. MCSDK 4.3 docmentation.
lluke.3
Thanks your support, I have found by source code.
CLutz.1
Can you share source code location? This could help others here.
Laurent Ca...
Lead II
The question has been moved from the "Motor Control Hardware" section to the "STM32 Motor Control" section (the question is about the STM32 MC SDK).
Best regards
