Using STM32F103VC in MC workbench
‎2019-06-25 8:40 AM
Hi, I have some question on mcu selection in MC workbench. As I have previous build an application based on STM32F103VC, I would like to use MC workbench to do configration. However, i cannot select it from the list. Are there any other solution? Thank You
- Labels:
STM32 Motor Control
STM32F1 Series
‎2019-07-09 10:32 AM
The best solution is to select the closest MCU available, and once the IOC is generated, you can open a new project with cubeMX with the right part number (STM32F103VC in your case) and import the IOC generated by the MotorControl workbench into your new IOC. Once it is done , if all the pins are matching, you can generate your project, otherwise you have to adapt the pinning configuration before generation.
It should do the trick. Let us know.
Cedric
‎2021-06-22 1:28 AM
The question has been moved from the section "Motor Control Hardware" to the "STM32 Motor Control" section (the question is about the STM32 MC SDK).
Best regards
