Updating motor mechanical parameters : Inertia and friction
‎2025-02-16 12:19 PM
I am trying to control a 24V PMSM type motor using ST Motor Control Workbench version 6.3.1 with the FOC.
I have run Motor Profiler and then gotten the electrical and mechanical parameters.
I have three questions and can anybody help/answer them?
- I am running Motor Profiler without load? Am I doing correct?
- When creating a project using Motor Control Workbench, do I need to update the inertia and friction coefficients in the motor stage depending on the load (please see attachment)? If the answer is no, where should I include the inertia and friction of the load in the project?
- May I measure PMSM type motor inertia and friction coefficients with load? If yes, how can I do it?
Thanks in advance.
‎2025-03-12 7:35 AM
Hello @EDokm,
You can profile your motor alone. In this case, once loaded, speed/torque regulator PID gain tuning has maybe to be done.
You can also profile the motor loaded if the profiler sequence isn’t a risk in your case (gear box or fan use case for example).
Best regards.
GMA
‎2025-03-12 7:35 AM
Hello @EDokm,
Best regards.
GMA
