STM32F407 - Servo Motor (SG90) is not work. (PWM output and motor seem to be working properly)
barisC
Hello, I am trying to learn bare metal programming and servo motor control with my stm32f407g-disc1 card.
I cannot move the servo motor with stm. I tried with arduino to check if the problem is in the motor and the motor worked. I thought my PWM signal was wrong and I found codes from the internet but it didn't work again.
I am attaching the code and logic analyzer graphs. Can you help me what could be the problem?
void GPIO_Init(void);
void TIM2_Init(void);
void TIM4_ms_Delay(uint32_t delay);
void GPIO_Init(){
	RCC->AHB1ENR |= 1; //Enable GPIOA clock
	GPIOA->AFR[0] |= 0x00100000; // Select the PA5 pin in alternate function mode
	GPIOA->MODER |= 0x00000800; //Set the PA5 pin alternate function
void TIM2_Init(){
	RCC->APB1ENR |=1;
	TIM2->PSC = 16-1; //Setting the clock frequency to 1MHz.
	TIM2->ARR = 20000; // Total period of the timer
	TIM2->CNT = 0;
	TIM2->CCMR1 = 0x0060; //PWM mode for the timer
	TIM2->CCER |= 1; //Enable channel 1 as output
	TIM2->CCR1 = 500; // Pulse width for PWM
void TIM4_ms_Delay(uint32_t delay){
	RCC->APB1ENR |= 1<<2; //Start the clock for the timer peripheral
	TIM4->PSC = 16000-1; //Setting the clock frequency to 1kHz.
	TIM4->ARR = (delay); // Total period of the timer
	TIM4->CNT = 0;
	TIM4->CR1 |= 1; //Start the Timer
	while(!(TIM4->SR & TIM_SR_UIF)){} //Polling the update interrupt flag
	TIM4->SR &= ~(0x0001); //Reset the update interrupt flag
int main(){
	RCC->CFGR |= 0<<10; // set APB1 = 16 MHz
	GPIO_Init();
	TIM2_Init();
	TIM2->CR1 |= 1;
	while(1){
		if(TIM2->CCR1 < 2500){
			TIM2->CCR1 = TIM2->CCR1 + 50;
			TIM4_ms_Delay(50);
		else{
			TIM2->CCR1 = 500;
			TIM4_ms_Delay(50);
Edit: I tried with HAL library but nothings change. Is it possible my STM is broken?
For HAL library, I follow this videos instruction: https://www.youtube.com/watch?v=owbuhblItBA
barisC
Okay, after researching the problems for two days, I bought a new servo motor of the same model. And code is working with new motor. I still have no idea why the old motor does not work with stm32.
I didn't see anything about closing the topic, but if any mod sees this message, you can close the topic.
3 REPLIES 3
Javier1
Principal
what about the logic level?
Is your arduino 5v and your stm 3v3?
we dont need to firmware by ourselves, lets talk
barisC
Yes, arduino gives 5v and stm32 gives 3v3 output voltage.That sounds like it could be a problem, but I didn't see anyone except me using the same card and the same motor and having problems. Am I missing something?
barisC
