Speed control
ā2023-07-18 9:28 PM
how we can change the speed of motor in STEVAL -SPIN3201 using external Potentionmeter?/or inbuilt Potentionmeter (Variable resistor )?
ā2023-07-19 12:00 AM
Hello Ranjeet Singh,
Using the MCSDK 6.1.2, you can enable the potentiometer while configuring your project via WorkBench.
Under Stage Configuration, check the Potentiometer box :
The generated project should include a speed control using the board's potentiometer.
Hope this will help,
Gaƫl A.
Gaƫl A.
Gaƫl A.
Gaƫl A.
ā2023-07-19 4:45 AM
how to solve this in old software 5.4.7 ?
ā2023-07-20 12:14 AM
Unfortunately, the potentiometer feature was not available in MCSDK 5.4.7 and was introduced in version 6.0.
However, you can still implement it yourself with a bit of coding.
Gaƫl A.
Gaƫl A.
ā2023-07-28 4:50 AM
sir ,can i know how i can add this coding?
ā2023-07-29 2:19 AM
It's not something you click to "add". In this context "coding" is a verb and means you have to develop/write code!
ā2023-08-04 9:00 PM
yeah sir,i got your point ,but from where i can get this code,can you share code?or code link
ā2023-08-07 12:13 AM
In my opinion, the easiest way to do it is to generate two projects using MCSDK 6.1.2 : one with potentiometer enabled and the other without, and see what the differences are so you can copy the potentiometer related part of the code to your 5.4.7 project.
Gaƫl A.
Gaƫl A.
ā2023-08-07 9:28 AM - edited ā2023-08-07 9:29 AM
Not "get" that code somewhere, but, as Gaƫl already said: "implement it yourself" Which part of that phrase you don't understand? It means creating a code, not copying.
ā2023-11-10 2:33 AM
How do I set what this potentiometer is used for?
For example, by default it seems to be used for setting speed, but what if I want to use it for setting any other value, like max torque, position or max amperage value?
Likewise, what happens if I have more than one Potentiometer on my board, how do I change which is used for what?
