Problem to Flash STEVAL SPIN 3201 Board Example
‎2020-10-21 9:39 AM
I have a STEVAL-SPIN3201 board Rev 3.
Try to use the flash procedure from document UM2152
- USB Connection to Windows 10 PC
- 12V Power Supply to J2
- Flash drive shows up with two files Fail.txt and Details.txt
- I am able to delete the two files.
- Windows shows a free memory of 24kB.
- 12kB are always used.
- Try to copy the SDK5x - STEVAL-SPIN3201 - BullRunning.bin example.
- Windows refuses to copy because of insufficient space.
Is there any procedure to get the 12kB free?
Thanks in advance and best regards
Jens
- Labels:
STM32 Motor Control
‎2020-10-21 12:07 PM
I found the problem... I had to update the STLINK SW on the board. This can be done with the STM32cubeProgrammer SW
‎2020-10-21 12:24 PM
Dear @JHenn.2​
But you are welcome =) !
Best regards
Laurent Ca...
