OV_VOLTAGE_THRESHOLD_V parameter in the MCSDK 6.1 generated code.
ASaha.3
I am having issue to find a work around this parameter.
I do not specifically set any over voltage threshold but it seems to be present there already, so i am guessing that's something hard wired by ST.
Is there a way, other than changing manually to change this value?
Thanks in advance.
Zied b.
Hello, the 2 values ​​of OV_VOLTAGE_THRESHOLD_V and UD_VOLTAGE_THRESHOLD_V are those defined in the MC WorkBench, you can modify them otherwise they are entered by default.
In the tab "Bus Voltage Sensing" on workbench
If you agree with my answer, please accept it by clicking on "Accept as solution".
1 REPLY 1
Zied b.
