2024-01-12 04:21 PM
If I could find some information about the implementation of the ZeST algorithm, I could try to infer whether it can be used on the B-G431B-ESC1 looking its schematic, but I can't find anything about it. So, will this new algorithm be available on the B-G431B-ESC1 board, or it needs some specific hardware to measure some extra parameter?
If I deduced correctly, the ZeST algorithm is able to calculate the angle of the motor's shaft, I guess that having into account the effect the inductance change produces on the signal, like a variable inductor dependent on the shaft's angle, is that right?
Thanks!
2024-01-15 12:34 AM
Hello bernat2,
For information on the availability of the STM32 ZeST software algorithm, please contact your ST sales office. However, I can already tell you that this algorithm will not be able to run on a B-G431-ESC1 ; evaluation can be done on the B-G473E-ZEST1S control board together with the STEVAL-LVLP01 power board.
This is what we mention in the page STM32 ZeST solution.
2024-01-15 12:34 AM
Hello bernat2,
