2024-03-28 4:17 AM
I'm working on a custmoize inverter board .
and I wan't to use Three-Shunt variants for current sensing, I implemented it in hwVariants, according to the documentation.
See the following :
"type": "inverter",
"name": "testNow",
"descVersion": 4,
"contentVersion": "1.1",
"PN": "testNow",
"longDescription": "",
"shortDescription": "",
"link": "",
"mcu": "STM32F303RCTx",
"clockSource": "8_crystal",
"clockFrequency": 72,
"motorDrives": [
"name": "M1",
"maxRatedVoltage": 600,
"minRatedVoltage": 300,
"maxRatedCurrent": 10,
"features": [
"name": "CurrentSensing",
"type": "CurrentSensing",
"tRise": 2550,
"hwVariants": [
"type": "ThreeShunt_AmplifiedCurrents",
"help": " ",
"shuntResistor": 0.01,
"amplifyingNetworkImax": 9,
"amplifyingNetworkVm": 3.3,
"amplifyingNetworkPrating": 2.0,
"offsetNetworkAttenuation": 1,
"opAmpGain": 2,
"polarizationOffset": 1.86,
"signals": {
"CURRENT_AMPL_U": [
"name": "PA7",
"help": "",
"cost": 0
"CURRENT_AMPL_V": [
"name": "PA6",
"help": "",
"cost": 0
"CURRENT_AMPL_W": [
"name": "PA3",
"help": "",
"cost": 0
"type": "SingleShunt_AmplifiedCurrents",
"help": " ",
"opAmpGain": 2,
"signals": {
"CURRENT_AMPL": [
"name": "PA2",
"help": "",
"cost": 0
"name": "PhaseVoltageGeneration",
"type": "PhaseVoltageGeneration",
"driverName": "",
"driverPN": "",
"minDeadTime": 100,
"maxSwitchingFreq": 100,
"tNoise": 2000,
"hwVariants": [
"type": "DrivingHighAndLowSides",
"help": "",
"deadTime": 100,
"highSideSwitchesDrivingPolarity": "Active high",
"lowSideSwitchesDrivingPolarity": "Active high",
"signals": {
"PWM_CHU_H": [
"name": "PA8",
"help": "",
"cost": 0
"PWM_CHV_H": [
"name": "PA9",
"help": "",
"cost": 0
"PWM_CHW_H": [
"name": "PA10",
"help": "",
"cost": 0
"PWM_CHU_L": [
"name": "PB13",
"help": "",
"cost": 0
"PWM_CHV_L": [
"name": "PB14",
"help": "",
"cost": 0
"PWM_CHW_L": [
"name": "PB15",
"help": "",
"cost": 0
"name": "VBusSensing",
"type": "VBusSensing",
"busVoltageDivider": 136,
"hwVariants": [
"help": "",
"signals": {
"VBUS": [
"name": "PA1",
"help": "",
"cost": 0
"busVoltageDividerR1": 1620,
"busVoltageDividerR2": 12,
"busVoltageDividerR3": null
"features": [
"name": "SerialPortCommunication",
"type": "SerialPortCommunication",
"hwVariants": [
"type": "Uart2WiresCommunication",
"help": "",
"signals": {
"UART_TX": [
"name": "PC10",
"help": "",
"cost": 0
"UART_RX": [
"name": "PC11",
"help": "",
"cost": 0
and then the picture show in MC Workbench:
only show one shunt Resistor. I don't know what's wrong with it. need to help!!!
2024-03-28 10:21 AM
Hello @tonyqian926 ,
Your issue comes from the pin you selected.
PA7 -> ADC2_IN4
PA6 -> ADC2_IN3
PA3 -> ADC1_IN4
The algorithm uses only 2 phases among the 3 (depending on the angle). If there is only 1 ADC connected to the 3 phases, then it does the 2 sampling sequentially. But if there is 2 ADCs, the idea is to be able to do the sampling of the two phases in the same clock cycle. To do so, one of the 3 pins must be accessible to the 2 ADCs.
In your case the suggestion will be then :
- replacing PA3 by PA5 -> ADC2_IN2, then you will have a proposal using only ADC2.
- replacing PA6 by PC3 -> ADC1_IN9, ADC2_IN9, then you will be able to use 2 ADCs with the following schema :
(U,V) sampled by ADC2_IN4, ADC1_IN9
(U,W) sampled by ADC2_IN4, ADC1_IN4
(V,W) sampled by ADC2_IN9, ADC1_IN4
Here the phase V is shared between ADC1 and ADC2.
Cedric
2024-03-28 10:21 AM
PA7 -> ADC2_IN4
PA6 -> ADC2_IN3
PA3 -> ADC1_IN4
Cedric
2024-03-29 2:37 AM
thanks very much, I can see 3 shunt now.
another question, there is some problem about the OCP function.
the json file
"type": "inverter",
"name": "testNow",
"descVersion": 4,
"PN": "testNow",
"link": "",
"motorDrives": [
"name": "M1",
"features": [
"tRise": 2550,
"hwVariants": [
"help": " ",
"opAmpGain": 2,
"signals": {
"CURRENT_AMPL_U": [
"name": "PA7",
"help": "",
"cost": 0
"CURRENT_AMPL_V": [
"name": "PC3",
"help": "",
"cost": 0
"CURRENT_AMPL_W": [
"name": "PA5",
"help": "",
"cost": 0
"help": "Soldering the pins SENS1 to Vshunt_2 of connector J5 and the pins SENS3 to Vshunt_2 of the connector J6",
"signals": {
"CURRENT_AMPL": [
"name": "PA2",
"help": "CN7.36. Factory default. Solder R48.",
"cost": 0
"amplifyingNetworkImax": 30,
"amplifyingNetworkPrating": 4,
"offsetNetworkAttenuation": 0.909,
"opAmpGain": 5.7,
"polarizationOffset": 1.710
"name": "OverCurrentProtection",
"type": "OverCurrentProtection",
"hwVariants": [
"type": "OnPowerStageOCP",
"help": "How to enable this variant",
"signals": {
"OC_TRIGGER": [
"name": "PA2",
"help": "",
"cost": 0
"OCThreshold": 480,
"OCComparatorThreshold": 0.3,
"OCNetworkOffset": 0,
"OCNetworkGain": 0.01,
"OCSignalPolarity":"Active low"
"driverName": "",
"driverPN": "",
"minDeadTime": 100,
"tNoise": 2000,
"hwVariants": [
"help": "",
"deadTime": 100,
"signals": {
"PWM_CHU_H": [
"name": "PA8",
"help": "",
"cost": 0
"PWM_CHV_H": [
"name": "PA9",
"help": "",
"cost": 0
"PWM_CHW_H": [
"name": "PA10",
"help": "",
"cost": 0
"PWM_CHU_L": [
"name": "PB13",
"help": "",
"cost": 0
"PWM_CHV_L": [
"name": "PB14",
"help": "",
"cost": 0
"PWM_CHW_L": [
"name": "PB15",
"help": "",
"cost": 0
"hwVariants": [
"help": "",
"signals": {
"VBUS": [
"name": "PA1",
"help": "",
"cost": 0
"name": "TemperatureSensing",
"type": "TemperatureSensing",
"hwVariants": [
"type": "NTCThermistor",
"help": "",
"signals": {
"TEMPERATURE_NTC": [
"name": "PB0",
"help": "",
"cost": 0
"v0": 1055,
"t0": 25,
"gain": 22.7,
"maxSensorTemperature": 110
"name": "ICL",
"type":"ICL",
"hwVariants": [
"type": "InrushCurrentLimiter",
"signals":{
"ICL_ENABLE": [
"name":"PD2",
"help":"hello",
"cost": 0
"switchPolarity": "Active high",
"capsDelayCharging": 100
"features": [
"hwVariants": [
"help": "",
"signals": {
"UART_TX": [
"name": "PC10",
"help": "",
"cost": 0
"UART_RX": [
"name": "PC11",
"help": "",
"cost": 0
the over current protection is not show on. I don't know why?
2024-03-29 7:29 PM
it's ok now. I changed the oc_trigger pin to PA2(TIMx_BKIN).I hadn't noticed it before.
the json code is:
"hwVariants": [
"signals": {
"OC_TRIGGER": [
"name": "PA2",
"help": "",
"cost": 0
"OCThreshold": 480,
and the foc wizard show:
