is anything wrong in my invert.json?
tonyqian926
I'm working on a custmoize inverter board .
and I wan't to use Three-Shunt variants for current sensing, I implemented it in hwVariants, according to the documentation.
See the following :
  "type": "inverter",
  "name": "testNow",
  "descVersion": 4,
  "contentVersion": "1.1",
  "PN": "testNow",
  "longDescription": "",
  "shortDescription": "",
  "link": "",
  "mcu": "STM32F303RCTx",
  "clockSource": "8_crystal",
  "clockFrequency": 72,
  "motorDrives": [
      "name": "M1",
      "maxRatedVoltage": 600,
      "minRatedVoltage": 300,
      "maxRatedCurrent": 10,
      "features": [
          "name": "CurrentSensing",
          "type": "CurrentSensing",
          "tRise": 2550,
          "hwVariants": [
              "type": "ThreeShunt_AmplifiedCurrents",
              "help": " ",
              "shuntResistor": 0.01,
              "amplifyingNetworkImax": 9,
              "amplifyingNetworkVm": 3.3,
              "amplifyingNetworkPrating": 2.0,
              "offsetNetworkAttenuation": 1,
              "opAmpGain": 2,
              "polarizationOffset": 1.86,
              "signals": {
                "CURRENT_AMPL_U": [
                    "name": "PA7",
                    "help": "",
                    "cost": 0
                "CURRENT_AMPL_V": [
                    "name": "PA6",
                    "help": "",
                    "cost": 0
                "CURRENT_AMPL_W": [
                    "name": "PA3",
                    "help": "",
                    "cost": 0
              "type": "SingleShunt_AmplifiedCurrents",
              "help": " ",
              "opAmpGain": 2,
              "signals": {
                "CURRENT_AMPL": [
                    "name": "PA2",
                    "help": "",
                    "cost": 0
          "name": "PhaseVoltageGeneration",
          "type": "PhaseVoltageGeneration",
          "driverName": "",
          "driverPN": "",
          "minDeadTime": 100,
          "maxSwitchingFreq": 100,
          "tNoise": 2000,
          "hwVariants": [
              "type": "DrivingHighAndLowSides",
              "help": "",
              "deadTime": 100,
              "highSideSwitchesDrivingPolarity": "Active high",
              "lowSideSwitchesDrivingPolarity": "Active high",
              "signals": {
                "PWM_CHU_H": [
                    "name": "PA8",
                    "help": "",
                    "cost": 0
                "PWM_CHV_H": [
                    "name": "PA9",
                    "help": "",
                    "cost": 0
                "PWM_CHW_H": [
                    "name": "PA10",
                    "help": "",
                    "cost": 0
                "PWM_CHU_L": [
                    "name": "PB13",
                    "help": "",
                    "cost": 0
                "PWM_CHV_L": [
                    "name": "PB14",
                    "help": "",
                    "cost": 0
                "PWM_CHW_L": [
                    "name": "PB15",
                    "help": "",
                    "cost": 0
          "name": "VBusSensing",
          "type": "VBusSensing",
          "busVoltageDivider": 136,
          "hwVariants": [
              "help": "",
              "signals": {
                "VBUS": [
                    "name": "PA1",
                    "help": "",
                    "cost": 0
              "busVoltageDividerR1": 1620,
              "busVoltageDividerR2": 12,
              "busVoltageDividerR3": null
  "features": [
      "name": "SerialPortCommunication",
      "type": "SerialPortCommunication",
      "hwVariants": [
          "type": "Uart2WiresCommunication",
          "help": "",
          "signals": {
            "UART_TX": [
                "name": "PC10",
                "help": "",
                "cost": 0
            "UART_RX": [
                "name": "PC11",
                "help": "",
                "cost": 0
and then the picture show in MC Workbench:
only show one shunt Resistor. I don't know what's wrong with it. need to help!!!
cedric H
Hello @tonyqian926 ,
Your issue comes from the pin you selected.
PA7 -> ADC2_IN4
PA6 -> ADC2_IN3
PA3 -> ADC1_IN4
The algorithm uses only 2 phases among the 3 (depending on the angle). If there is only 1 ADC connected to the 3 phases, then it does the 2 sampling sequentially. But if there is 2 ADCs, the idea is to be able to do the sampling of the two phases in the same clock cycle. To do so, one of the 3 pins must be accessible to the 2 ADCs.
In your case the suggestion will be then :
- replacing PA3 by PA5 -> ADC2_IN2, then you will have a proposal using only ADC2.
- replacing PA6 by PC3 -> ADC1_IN9, ADC2_IN9, then you will be able to use 2 ADCs with the following schema :
(U,V) sampled by ADC2_IN4, ADC1_IN9
(U,W) sampled by ADC2_IN4, ADC1_IN4
(V,W) sampled by ADC2_IN9, ADC1_IN4
Here the phase V is shared between ADC1 and ADC2.
Cedric
3 REPLIES 3
cedric H
PA7 -> ADC2_IN4
PA6 -> ADC2_IN3
PA3 -> ADC1_IN4
Cedric
tonyqian926
another question, there is some problem about the OCP function.
the json file
  "type": "inverter",
  "name": "testNow",
  "descVersion": 4,
  "PN": "testNow",
  "link": "",
  "motorDrives": [
      "name": "M1",
      "features": [
          "tRise": 2550,
          "hwVariants": [
              "help": " ",
              "opAmpGain": 2,
              "signals": {
                "CURRENT_AMPL_U": [
                    "name": "PA7",
                    "help": "",
                    "cost": 0
                "CURRENT_AMPL_V": [
                    "name": "PC3",
                    "help": "",
                    "cost": 0
                "CURRENT_AMPL_W": [
                    "name": "PA5",
                    "help": "",
                    "cost": 0
              "help": "Soldering the pins SENS1 to Vshunt_2 of connector J5 and the pins SENS3 to Vshunt_2 of the connector J6",
              "signals": {
                "CURRENT_AMPL": [
                    "name": "PA2",
                    "help": "CN7.36. Factory default. Solder R48.",
                    "cost": 0
              "amplifyingNetworkImax": 30,
              "amplifyingNetworkPrating": 4,
              "offsetNetworkAttenuation": 0.909,
              "opAmpGain": 5.7,
              "polarizationOffset": 1.710
          "name": "OverCurrentProtection",
          "type": "OverCurrentProtection",
          "hwVariants": [
              "type": "OnPowerStageOCP",
              "help": "How to enable this variant",
              "signals": {
                "OC_TRIGGER": [
                    "name": "PA2",
                    "help": "",
                    "cost": 0
              "OCThreshold": 480,
              "OCComparatorThreshold": 0.3,
              "OCNetworkOffset": 0,
              "OCNetworkGain": 0.01,
              "OCSignalPolarity":"Active low"
          "driverName": "",
          "driverPN": "",
          "minDeadTime": 100,
          "tNoise": 2000,
          "hwVariants": [
              "help": "",
              "deadTime": 100,
              "signals": {
                "PWM_CHU_H": [
                    "name": "PA8",
                    "help": "",
                    "cost": 0
                "PWM_CHV_H": [
                    "name": "PA9",
                    "help": "",
                    "cost": 0
                "PWM_CHW_H": [
                    "name": "PA10",
                    "help": "",
                    "cost": 0
                "PWM_CHU_L": [
                    "name": "PB13",
                    "help": "",
                    "cost": 0
                "PWM_CHV_L": [
                    "name": "PB14",
                    "help": "",
                    "cost": 0
                "PWM_CHW_L": [
                    "name": "PB15",
                    "help": "",
                    "cost": 0
          "hwVariants": [
              "help": "",
              "signals": {
                "VBUS": [
                    "name": "PA1",
                    "help": "",
                    "cost": 0
          "name": "TemperatureSensing",
          "type": "TemperatureSensing",
          "hwVariants": [
              "type": "NTCThermistor",
              "help": "",
              "signals": {
                "TEMPERATURE_NTC": [
                    "name": "PB0",
                    "help": "",
                    "cost": 0
              "v0": 1055,
              "t0": 25,
              "gain": 22.7,
              "maxSensorTemperature": 110
          "name": "ICL",
          "type":"ICL",
          "hwVariants": [
              "type": "InrushCurrentLimiter",
              "signals":{
                "ICL_ENABLE": [
                    "name":"PD2",
                    "help":"hello",
                    "cost": 0
              "switchPolarity": "Active high",
              "capsDelayCharging": 100
  "features": [
      "hwVariants": [
          "help": "",
          "signals": {
            "UART_TX": [
                "name": "PC10",
                "help": "",
                "cost": 0
            "UART_RX": [
                "name": "PC11",
                "help": "",
                "cost": 0
the over current protection is not show on. I don't know why?截屏2024-03-29 17.34.52.jpg
it's ok now. I changed the oc_trigger pin to PA2(TIMx_BKIN).I hadn't noticed it before.
the json code is:
          "hwVariants": [
              "signals": {
                "OC_TRIGGER": [
                    "name": "PA2",
                    "help": "",
                    "cost": 0
              "OCThreshold": 480,
and the foc wizard show:截屏2024-03-30 10.28.41.jpg
