Is anyone able to drive a BLDC motor at low speeds? anything below 6 RPM?
msingh
I am using the X-NUCLEO-IHM08M1 as a power board and NUCLEO-F303RE as a control board. Using an incremental encoder of 1024CPT I was able to drive the motor as slow as 6RPM, even after several attempts I was unable to achieve any lower speeds. When I request any lower speeds the motor stops and goes into the "lock rotor" meaning the motor stops rotating but still draws current.
Thanks In advance
Manpreet
msingh
Hi @Imen DAHMEN​ ,
I used position control instead of speed control which allowed to rotate slower than 6RPM, then adjusted PIDs to eliminate overshoots and vibrations, then I just had a bad connection and the motor simply stopped rotating ( I thought it was a firmware issue but it wasn't as it stopped working with the previous version of firmware) .
PID tuning is really a big issue. Personally I do not reccomend the Motor profiler as it is not usefull at all, the parameters should be used from the motor datasheet and PID tuning should be done manually.
9 REPLIES 9
mscot.1
Position control mode - AN5464 and set Duration to zero. It works.
msingh
Hi @mscot.1​ ,
Really appreciate your help. I will try this soon.
Kind Regards
Manpreet
Good morning mscot.1,
Thank you once again for your suggestion I have created a project using the AN5464 and the motor is able slower than 6RPM (I think) however I cannot use the "follow mode" as mentioned in the application note. When I set the duration to 0 it should start a continuous rotation if i keep updating the position however the rotor doesn't move at all. Is there any suggestion you have?
I would appreciate your help.
Kind Regards
Manpreet Singh
mscot.1
Sorry, I have not got anything more to offer; I followed the App Note and achieved the motor moving between 2 positions. Then I set the duration to zero and advanced the angle in a loop and it worked. That is as far as I went.
would you be kind enough to share the "loop" you have please?
I am able to move between 2 position however I cannot achieve any continuous movement, below is the code I am using.
msingh
Actually I have identified the issue. THANK YOU VERY MUCH FOR YOUR HELP. MUCH APPRECIATED :)
Have a nice day.
Kind Regards
Manpreet Singh
Hello @msingh​ ,
Please, let us know how you solved your issue ?
Then, please select the post which is "Best Answer" or mark your post as answered the question.
Best Regards
Imen
Imen
msingh
Hi @Imen DAHMEN​ ,
