I would like to know if either or both STEVAL-IHM040V1 and EVSPIN32F06Q1S3 are plug and play modules for controlling 3-Phase Sensorless Motors, and do not require initial software programming?
‎2021-02-10 3:38 PM
‎2021-05-19 7:45 AM
Yes , Can you share your motor detail as below ?
‎2021-05-19 7:49 AM
Are you able to generate the code ?
‎2021-05-19 7:52 AM
I have not yet connected the EVSPIN32F0601S3 to the motor.
Please see the picture of motor below:
Regards,Santos
‎2021-05-19 7:54 AM
I have not seen any picture . Please reload .
‎2021-05-19 8:06 AM
I lost the laptop and have not downloaded the mcsdk on the new laptop yet, but the following inputs that are different from your example above:
Poles Pairs: 6, Nnominal DC Voltage: 400 V.
Further information of the following title from STM32 Motor Control & STM32CubeMX:
Generated Project is showing IPConfigManager:1461 error.
‎2021-05-19 8:11 AM
1) Can you rewrite what problem(s) you are facing ?
2) Are you able to generate the code successfully ?
Karan
‎2021-05-19 8:14 AM
I will try again once I have the MCSDK running, then will confirm to you.
‎2021-05-19 8:16 AM
OK .. I am able to generate/compile the code successfully with MCSDK .
Are you?
Karan
‎2021-05-27 12:50 PM
Did you get some time?
​Are you able to spin the Motor?
‎2021-06-01 4:43 AM
Greetings Karan, thank you for your message, and apologise for my late reply and for not getting the time to spin the motor yet, which for personal issue I will not be able to do so until the month of August.
- « Previous
- Next »
