2025-03-18 7:58 PM
2025-03-19 6:22 AM
Hello z h,
In order to find a solution to your problem, I would like to know more about your motor's characteristics and application. Can you provide :
- Your Motor's parameters (Rs, Ls, Flux (Wb), PolePairs, Nominal Speed and Current)
- Your start-up conditions : Speed (or torque) target, speed ramp, Pulse Current goal
Concerning the behaviour of the system in Observing mode, be aware that this is absolutely normal. In Observing, nothing is done to the motor, only sampling are performed. This means that at low / zero speed, the B-EMF is very low and that speed and position estimations are totally incorrect. Observing is mainly relevant for verifying your offset measurements.
