2021-10-20 12:31 AM
Is st mc sdk support measure the motor parameter only use the board, not use STMotorProfiler?
It is useful to driver different motor when the foc board used as a general driver product.
2021-10-20 2:37 AM
STMotorprofiler is part of the MC SDK delivery.
You can profile your motor only with the boards combination proposed by the Motor profiler.
Cedric
2021-10-20 2:37 AM
Cedric
