Hello DMeie.2,
Yes you are right, sorry for the inconvenience.
As a workaround, I would suggest to create a project with a positive gain and save the following values:
- In Speed Sensing config panel->Observer and PLL: G2 gain (if you are in sensorless mode)
- In Drive setting: torque and flux current regulator PI gains
- In Drive setting: speed regulator PI gains
Then in your project with negative gain, port the values previously saved:
- In Speed Sensing config panel->Observer and PLL: uncheck Auto Calculate box and copy the G2 gain from the project with positive gain
- In Drive setting: uncheck Auto Calculate Torque/Flux Kp & Ki box and copy torque and flux current regulator PI gains from the project with positive gain
- In Drive setting: uncheck Auto Calculate Kp & Ki box and torque and copy speed regulator PI gains from the project with positive gain
This should generate a project with correct gains and inverted current values.
Best regards
If you agree with my answer, please consider accepting it by clicking on 'Accept as solution'.
