2020-06-11 12:22 AM
Hello Friends.
May you help me?
In Section 8.3 (hall sensor feedback processing) of STM32F SOC SDK manual.
This section mentions to Hall electrical phase shift.
So, could you tell me how to get the Hall electrical phase shift? what kind of equipment can I use to determine this parameter? such as oscilloscope or others?
Thank you so much.
2020-06-11 11:42 PM
Very often it is a good idea to mention the documents name/number due to thousands of documents available at STMicroelectronics website.
Currently you are referring to the document UM1052:
https://www.st.com/resource/en/user_manual/cd00298474.pdf
On page 93 you'll find the information how to measure. And yes, you need e.g. some oscilloscope.
Best regards
/Peter
2021-06-15 12:43 AM
The question has been moved from the "Motor Control Hardware" section to the "STM32 Motor Control" section (the question is about the STM32 MC SDK).
Best regards
2022-07-07 06:44 AM
On page 93, it doesn't tell you how to calculate. It simply tells to put the value in the ST GUI.
