2023-11-15 10:27 PM
What is speed feedback error fault in motor control workbench?
2023-11-15 11:27 PM
If using Hall sensors then the speed feedback fault indicates problem with the hall sensors signals, implies a problem in calculating the position information of the rotor.
2023-11-17 12:29 AM
Hello vishu,
You can find more information on Speed Feedback error by reading the MCSDK 6.2 documentation. Via Workbench, you can access it by clicking About -> Documentations -> Documentation and then in the html page go to User Manual -> Firmware errors. You will find a list of all firmware errors as well as their description.
2023-11-17 02:48 AM
which hall sensor signals?? Please ellaborate.
2023-11-17 02:49 AM
can you please send me pdf format of documentation. Didnt open MCSDK version 6 in my pc
2023-11-17 02:58 AM
Do you use sensored or sensorless FOC? in case of sensorless algorithm Hall sensor signals what i mentioned is not applicable for speed feedback fault. For MCSDK6.2.0 the documentation is available in the installation folder under Documentation as html files.
2023-11-17 04:25 AM
I used MCSDK 5.4.8 version for 6-step algorithm for hall sensor.
2023-11-17 04:59 AM
Hello vishu,
You can find MCSDK v5.4.8 documentation in the top left corner by clicking on : Documentation -> STM32- motor control SDK5.x - Firmware. The information you are looking for should be available at section 3.4.5 Fault Handling on page 39.
