(Bug Report) When using encoder, the generated code has a few defects - speed calculation is not reliable, no speed reliability check, and no scheme to clear speed feedback fault
2022-01-19 12:48 AM
(Environment)
MC_SDK 5.Y.3 + STM32CubeMX 6.3.0 with HAL + IAR EWARM 8.5
(Hardware)
custom board based on F446RE + custom power board + Low Voltage BLDC motor with Encoder
(Control Mode)
Speed Control
(What I found)
(1) speed calculation is not reliable
[ ENC_CalcAvrgMecSpeedUnit() in encoder_speed_pos_fdbk.c ]
Encoder direction and UP(overflow/underflow) count are used to calculate the delta.
This algorithm lead, however, to an incorrect result in the following case:
- During speed loop (1msec), assume encoder direction has been up-counting so far
- That is, speed is (+) and delta is (+)
- However, just when ENC_CalcAvrgMecSpeedUnit() is called, encoder direction could be changed to down-counting
- (+)delta and down-counting results in incorrectly adding encoder pulse number
This case can happen when the motor is hunting around zero speed, including encoder alignment.
if ( directionSample == LL_TIM_COUNTERDIRECTION_DOWN ) {
/* encoder timer down-counting*/
OverflowCntSample = ( CntCapture > pHandle->PreviousCapture ) ? 1 : 0;
pHandle->DeltaCapturesBuffer[pHandle->DeltaCapturesIndex] =
( int32_t )( CntCapture ) - ( int32_t )( pHandle->PreviousCapture ) -
( ( int32_t )( OverflowCntSample ) + OFbit ) * ( int32_t )( pHandle->PulseNumber );
(2) no speed reliability check
[ TSK_MediumFrequencyTaskM1() in mc_task.c ]
- In case of using encoder
__weak void TSK_MediumFrequencyTaskM1(void)
(void) ENC_CalcAvrgMecSpeedUnit( &ENCODER_M1, &wAux );
case RUN:
MCI_ExecBufferedCommands( &Mci[M1] );
FOC_CalcCurrRef( M1 );
break;
- In case of using hall sensor
bool IsSpeedReliable = HALL_CalcAvrgMecSpeedUnit( &HALL_M1, &wAux );
case RUN:
if( !IsSpeedReliable )
STM_FaultProcessing( &STM[M1], MC_SPEED_FDBK, 0 );
break;
(3) no scheme to clear speed feedback fault once happened
[ SPD_IsMecSpeedReliable() in speed_pos_fdbk.c ]
"ENCODER_M1._Super.bSpeedErrorNumber" is incremented to its max(default:3) then generating an alarm, but no state transition or API to reset this value to zero.
- Labels:
STM32 Motor Control
STM32F4 Series
2022-01-25 4:39 PM
I added additional issues after more test.
2022-02-14 3:51 PM
Please could someone ST member clarify this issue?
2022-03-02 10:17 AM
Hello @THA.1 ,
Thanks for your post.
I do agree with you. We have an issue if we have a speed inversion between two sampling events. This could happen if the motor speed is around 0.
We need to internally check what would be the best way to solve this tricky case.
Cedric
2022-03-02 4:15 PM
Thank you for your reply.
Just a traditional way would be a good choice if sampling frequency is high enough - determining overflow/underflow by the amount of change of the counter.
THA.1
