Accessing register [2841] THROTTLE_POS resulted in error[5].
Takumi Lee
[WARNING] - MotorControlRegistersBank: Accessing register [2841] THROTTLE_POS resulted in error[5] . Changing register's access accordingly to avoid getting this error again
I didn't turn on the potentiometer, please fix that.
Control Board B-G473E-ZEST1S
Power Board STEVAL-LVLP01
Speed Sensor Mode:HSO
GMA
Hello @Takumi Lee,
This is only a warning message from the MC Pilot notifying that a register is not accessible (if it is not present on the project for example). There is no impact on your use-case.
If you agree with the answer, please accept it by clicking on 'Accept as solution'.
Best regards.
GMA
1 REPLY 1
GMA
Hello @Takumi Lee,
Best regards.
GMA
