2025-02-09 9:51 AM - last edited on 2025-02-27 7:57 AM by Andrew Neil
[WARNING] - MotorControlRegistersBank: Accessing register [2841] THROTTLE_POS resulted in error[5] . Changing register's access accordingly to avoid getting this error again
I didn't turn on the potentiometer, please fix that.
Control Board B-G473E-ZEST1S
2025-02-27 7:48 AM
Hello @Takumi Lee,
This is only a warning message from the MC Pilot notifying that a register is not accessible (if it is not present on the project for example). There is no impact on your use-case.
2025-02-27 7:48 AM
Hello @Takumi Lee,
