Which driver having lower execution time HAL or LL?
parth kothiya
Which driver is faster from HAL or LL so cpu can perform other important tasks.
For example to read & write gpio
​Using HAL driver,
Using LL driver,
Using direct access MCU resistor.​
Guru
Direct register access will always be the fastest.
4 REPLIES 4
Guru
S.Ma
Principal
You just described the list in increasing achievable performance level. Apart from this, maybe not all the code requires to be best performance...
Can we use both drivers in same application code writing using HAL + LL + Direct access MCU resistor all of this?​
Yes. A little silly to do so, however. Need to ensure the HAL state machine doesn’t get disturbed but your other code.
